Saltar al contenido principal
Dell Latitude 7420 Keyboard Replacement
Inglés
Español
Paso 3
Dell Latitude 7420 Keyboard Replacement: paso 0, imagen 1 de 3 Dell Latitude 7420 Keyboard Replacement: paso 0, imagen 2 de 3 Dell Latitude 7420 Keyboard Replacement: paso 0, imagen 3 de 3
  • Remove the connectors to the system board.
  • Place the tip of your opening tool under the edge of the connector, and pry the connector straight up from its socket.
  • Use the tip of a spudger or your fingernail to flip up the small locking flaps from these ZIF connectors. Then, you can safely pull the cables out.
  • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to disconnect these coaxial cables.
  • To remove the blue connector, pull the cable away from the connector in the same direction that the individual wires are running.
  • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  • Lift the final connector up from the socket.
Insertar traducción aquí
