Saltar al contenido principal
Dell Inspiron 15-3567 Fan Replacement
Inglés
Español
Paso 13
Dell Inspiron 15-3567 Fan Replacement, Remove the Bottom Case: paso 0, imagen 1 de 3 Dell Inspiron 15-3567 Fan Replacement, Remove the Bottom Case: paso 0, imagen 2 de 3 Dell Inspiron 15-3567 Fan Replacement, Remove the Bottom Case: paso 0, imagen 3 de 3
  • Slowly press the bottom case down using the hole on the upper case.
  • You should be able to hear some cracking sounds and have some gaps between the upper and bottom case.
  • Using those gaps, slowly separate the left part of your laptop.
Insertar traducción aquí
