Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 10 guías que incluyen este paso.
Traduciendo paso 1
Paso 1
Peel off the graphite foil
Use a pair of tweezers to carefully peel the graphite foil off the battery and midframe.
[title] Peel off the graphite foil | |
- | [* black] Use a pair of tweezers to carefully peel the graphite foil off the battery and midframe. |
+ | [* black] Use a pair of [product|IF145-020|tweezers] to carefully peel the graphite foil off the battery and midframe. |
[* icon_caution] Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire. | |
[* icon_note] If you're having a hard time peeling off the foil, you can apply a [guide|25705|heated iOpener|new_window=true] to the back of the device for two minutes to loosen its adhesive. |
