Saltar al contenido principal
Opening Procedure
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 73 guías que incluyen este paso.
Inglés
Holandés
Paso 3
Opening Procedure, Anti-Clamp instructions: paso 0, imagen 1 de 3 Opening Procedure, Anti-Clamp instructions: paso 0, imagen 2 de 3 Opening Procedure, Anti-Clamp instructions: paso 0, imagen 3 de 3
  • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
  • For complete instructions on how to use the Anti-Clamp, check out this guide.
  • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
  • Place an object under your iPad so it rests level between the suction cups.
  • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
  • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
  • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
Insertar traducción aquí
