Saltar al contenido principal
Opening Procedure
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 73 guías que incluyen este paso.
Inglés
Holandés
Paso 20
Opening Procedure, Separate the bottom adhesive: paso 0, imagen 1 de 3 Opening Procedure, Separate the bottom adhesive: paso 0, imagen 2 de 3 Opening Procedure, Separate the bottom adhesive: paso 0, imagen 3 de 3
  • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
  • Slide the pick over the antenna, stopping just before the home button.
  • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
  • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
  • Leave the pick to the left of the home button before continuing.
Insertar traducción aquí
