Saltar al contenido principal
Opening Procedure
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 73 guías que incluyen este paso.
Inglés
Holandés
Paso 7
Opening Procedure, Separate the left adhesive: paso 0, imagen 1 de 3 Opening Procedure, Separate the left adhesive: paso 0, imagen 2 de 3 Opening Procedure, Separate the left adhesive: paso 0, imagen 3 de 3
  • Insert a second opening pick into the gap you just created.
  • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
  • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
  • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
Insertar traducción aquí
