Saltar al contenido principal
iPad 8 LTE Right Bluetooth and Wi-Fi Antenna Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Holandés
Paso 7
iPad 8 LTE Right Bluetooth and Wi-Fi Antenna Replacement: paso 0, imagen 1 de 3 iPad 8 LTE Right Bluetooth and Wi-Fi Antenna Replacement: paso 0, imagen 2 de 3 iPad 8 LTE Right Bluetooth and Wi-Fi Antenna Replacement: paso 0, imagen 3 de 3
  • The antenna cable is anchored to the speaker with a small metal bracket. The bracket is permanently crimped to the antenna and adhered to the speaker enclosure. The adhesive must be severed in order to extract the antenna.
  • Carefully insert an opening pick between the speaker enclosure and the bracket.
  • Slide the pick toward the charging port to cut the adhesive.
  • Push the bracket away from the speaker until it clears the tape underneath.
Insertar traducción aquí
