Saltar al contenido principal
iPhone SE 2022 Vervanging van de batterij
Inglés
Holandés
Paso 6
iPhone SE 2022 Battery Replacement: paso 0, imagen 1 de 3 iPhone SE 2022 Battery Replacement: paso 0, imagen 2 de 3 iPhone SE 2022 Battery Replacement: paso 0, imagen 3 de 3
  • If you don't have any high concentration (over 90%) isopropyl alcohol at hand you can prepare an iOpener and apply it to the rear glass for at least three minutes to loosen the stretch-release adhesive underneath the battery.
  • Insert a plastic card underneath the bottom edge of the battery.
  • Slide the plastic card along the edge of the battery to separate it from the rear case and to cut the adhesive.
  • Use your plastic card to carefully pry up the battery.
Als je geen isopropyl alcohol (>90%) voorhanden hebt, kun je ook een iOpener verwarmen en deze gedurende minimaal drie minuten op de glazen achterkant leggen om de lijm onder de batterij te verzwakken.
Steek een plastic kaart onder de onderkant van de batterij.
Schuif je plastic kaart langs de rand van de batterij om deze van de achterste behuizing te scheiden en de lijm door te snijden.
Gebruik je plastic kaart om de batterij op voorzichtige wijze omhoog te wrikken.
[* black] If you don't have any high concentration (over 90%) isopropyl alcohol at hand you can [guide|25705|prepare an iOpener|new_window=true] and apply it to the rear glass for at least three minutes to loosen the stretch-release adhesive underneath the battery.
-[* black] Insert a plastic card underneath the bottom edge of the battery.
+[* black] Insert a [product|IF145-101|plastic card] underneath the bottom edge of the battery.
[* black] Slide the plastic card along the edge of the battery to separate it from the rear case and to cut the adhesive.
[* black] Use your plastic card to carefully pry up the battery.
