Saltar al contenido principal
Dell Latitude E6400 Teardown
Inglés
Holandés
Paso 11
Dell Latitude E6400 Teardown, Upper Case: paso 0, imagen 1 de 1
Upper Case
  • If you skipped here without removing radiator you will need very narrow screwdriver in order to access screws underneath the fan bracket.
  • Remove the seven 4.8 mm Phillips screws securing the upper case.
  • Remove the two 4.8 mm Phillips screws securing the upper case.
Insertar traducción aquí
