Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 13 guías que incluyen este paso.
Traduciendo paso 2
Paso 2
Anti-Clamp instructions
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
[title] Anti-Clamp instructions | |
- | [* icon_note] The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. ***If you aren't using the Anti-Clamp, skip down three steps for an alternate method.*** |
+ | [* icon_note] The next three steps demonstrate the [product|IF145-513|Anti-Clamp], a tool we designed to make the opening procedure easier. ***If you aren't using the Anti-Clamp, skip down three steps for an alternate method.*** |
[* icon_note] For complete instructions on how to use the Anti-Clamp, [guide|152309|check out this guide|new_window=true]. | |
[* black] Pull the blue handle backwards to unlock the Anti-Clamp's arms. | |
[* black] Slide the arms over either the left or right edge of your iPhone. | |
[* black] Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back. | |
[* black] Squeeze the cups together to apply suction to the desired area. | |
[* icon_note] If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can [guide|159595|use tape|new_window=true] to create a grippier surface. |
