Saltar al contenido principal
Chevrolet SS Sedan Rear Strut Removal
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 4
Chevrolet SS Sedan Rear Strut Removal, Separate Knuckle from Lower Control Arm: paso 0, imagen 1 de 3 Chevrolet SS Sedan Rear Strut Removal, Separate Knuckle from Lower Control Arm: paso 0, imagen 2 de 3 Chevrolet SS Sedan Rear Strut Removal, Separate Knuckle from Lower Control Arm: paso 0, imagen 3 de 3
  • An 18mm nut and bolt secures the lower control arm to the rear knuckle and must be removed.
  • Like the strut-to-LCA bolt, this may require "finessing" the lower control arm with a jack to remove.
  • When reassembling, torque this to around 35ft-lbs. You will need to do some prying with a pry-bar or large screwdriver in concert with a jack to get this realigned so you can re-insert the bolt.
  • This nut is identical to the one removed in the previous step, but the bolt is shorter. Don't mix them up!
  • After this step, the lower control arm should move freely.
Insertar traducción aquí
