Traduciendo paso 3
Paso 3
Remove the front camera
Insert the point of a spudger into the gap between the frame and the front camera.
Pry up with the spudger to detach the front camera.
Use tweezers, or your fingers, to remove the front camera.
[title] Remove the front camera | |
[* black] Insert the point of a spudger into the gap between the frame and the front camera. | |
[* black] Pry up with the spudger to detach the front camera. | |
[* icon_note] If you're having trouble separating the front camera from the frame, apply more isopropyl alcohol; it may take a while for the adhesive to loosen. | |
- | [* black] Use tweezers, or your fingers, to remove the front camera. |
+ | [* black] Use [product|IF145-020|tweezers], or your fingers, to remove the front camera. |
