Saltar al contenido principal
Reemplazo de las cámaras frontales de Microsoft Surface Pro 6
Inglés
Español
Traduciendo paso 1
Paso 1
Microsoft Surface Pro 6 Front-Facing Cameras Replacement, Remove the camera connector shield: paso 0, imagen 1 de 3 Microsoft Surface Pro 6 Front-Facing Cameras Replacement, Remove the camera connector shield: paso 0, imagen 2 de 3 Microsoft Surface Pro 6 Front-Facing Cameras Replacement, Remove the camera connector shield: paso 0, imagen 3 de 3
  • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the camera connectors.
  • Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it.
  • Repeat this procedure at different points around the shield until it is free. Remove the shield.
  • Try not to deform the shield too much—you will need to reinstall it during reassembly.
Inserta una punta de un par de pinzas puntiagudas en un espacio en la esquina del escudo EMI que cubre los conectores de la cámara.
Usa las pinzas para separar el escudo EMI de la placa base tanto como pueda sin doblarlo.
Repite este procedimiento en diferentes puntos alrededor del escudo hasta que quede libre. Retire el escudo.
Trata de no deformar demasiado el protector; deberá volver a instalarlo durante el montaje.
[title] Remove the camera connector shield
-[* black] Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the camera connectors.
+[* black] Insert one point of a pair of [product|IF145-020-2|pointed tweezers] into a gap in the corner of the EMI shield covering the camera connectors.
[* black] Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it.
[* black] Repeat this procedure at different points around the shield until it is free. Remove the shield.
[* icon_caution] Try not to deform the shield too much—you will need to reinstall it during reassembly.
