Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 13 guías que incluyen este paso.
Traduciendo paso 19
Paso 19
Insert one point of a pair of pointed tweezers into a gap in the edge of the EMI shield covering the digitizer connector.
Use the tweezers to pry the EMI shield away from the display as much as you can without bending it.
Repeat this procedure at different points around the shield until it is free. Remove the shield.
- | [* black] Insert one point of a pair of pointed tweezers into a gap in the edge of the EMI shield covering the digitizer connector. |
+ | [* black] Insert one point of a pair of [product|IF145-020-2|pointed tweezers] into a gap in the edge of the EMI shield covering the digitizer connector. |
[* black] Use the tweezers to pry the EMI shield away from the display as much as you can without bending it. | |
[* black] Repeat this procedure at different points around the shield until it is free. Remove the shield. | |
[* icon_caution] Try not to deform the shield too much—you will need to reinstall it during reassembly. |
