Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 9 guías que incluyen este paso.
Traduciendo paso 1
Paso 1
Remove the heat sink shield
Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
[title] Remove the heat sink shield | |
- | [* black] Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink. |
+ | [* black] Insert one point of a pair of [product|IF145-020-2|pointed tweezers] into a gap in the corner of the EMI shield covering the heat sink. |
[* black] Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet. | |
[* icon_caution] Try not to deform the shield too much—you will need to reinstall it during reassembly. | |
[* icon_caution] Take care not to puncture the battery with the tweezers while working on this shield. |
