Saltar al contenido principal
Lenovo ThinkPad X1 Extreme Back Cover Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 13 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Lenovo ThinkPad X1 Extreme Back Cover Replacement: paso 0, imagen 1 de 3 Lenovo ThinkPad X1 Extreme Back Cover Replacement: paso 0, imagen 2 de 3 Lenovo ThinkPad X1 Extreme Back Cover Replacement: paso 0, imagen 3 de 3
  • Power off and unplug your device before you begin.
  • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
  • Unscrew the seven captive screws with a Phillips #00 screwdriver.
  • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
  • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
  • Remove the back cover from the device.
Insertar traducción aquí
