Saltar al contenido principal
Reemplazo de la caja trasera del mando del Sony DualSense
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 26 guías que incluyen este paso.
Inglés
Español
Paso 3
Rear Case Separation, Separate the rear case: paso 0, imagen 1 de 3 Rear Case Separation, Separate the rear case: paso 0, imagen 2 de 3 Rear Case Separation, Separate the rear case: paso 0, imagen 3 de 3
  • Be gently when releasing the rear cover clips—they're delicate and can easily break.
  • Use the point of a spudger to release the two clips on either side of the headset jack.
Usa el borde puntiagudo de un spudger para desenganchar los dos clips situados a ambos lados de la toma de auriculares.
-[* black] Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
+[title] Separate the rear case
+[* icon_caution] Be gently when releasing the rear cover clips—they're delicate and can easily break.
+[* black] Use the point of a spudger to release the two clips on either side of the headset jack.
