Saltar al contenido principal
Desoldar la placa madre
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Motherboard Desoldering, Desolder the vibration motors: paso 0, imagen 1 de 3 Motherboard Desoldering, Desolder the vibration motors: paso 0, imagen 2 de 3 Motherboard Desoldering, Desolder the vibration motors: paso 0, imagen 3 de 3
  • The next few steps require desoldering and soldering connections. To learn how to solder, check out our soldering guide—if you've already soldered, you can still find some helpful tips and tricks in this guide!
  • Flip over the controller and motherboard.
  • Use a soldering iron to desolder the vibration motor wires from the motherboard:
  • Two red wires
  • Two black wires
  • During reassembly, remember to solder the wires back into the same position. The red wires belong closest to the edge and next to the Rs on the motherboard.
Dale la vuelta al controlador y a la placa madre.
Utiliza un soldador para desoldar los cables del motor de vibración de la placa madre:
Dos cables rojos
Dos cables negros
Durante el montaje, recuerda que debes soldar los cables en la misma posición. Los cables rojos son los que están más cerca del borde y junto a las R de la placa madre.
[title] Desolder the vibration motors
+[* icon_note] The next few steps require desoldering and soldering connections. To learn how to solder, check out our [guide|750|soldering guide|new_window=true]—if you've already soldered, you can still find some helpful tips and tricks in this guide!
[* black] Flip over the controller and motherboard.
[* black] Use a soldering iron to desolder the vibration motor wires from the motherboard:
[* red] Two red wires
[* black] Two black wires
[* icon_reminder] During reassembly, remember to solder the wires back into the same position. The red wires belong closest to the edge and next to the ***R***s on the motherboard.
