Saltar al contenido principal
Reemplazo de la caja trasera del mando del Sony DualSense
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 26 guías que incluyen este paso.
Inglés
Español
Paso 4
Rear Case Separation: paso 0, imagen 1 de 3 Rear Case Separation: paso 0, imagen 2 de 3 Rear Case Separation: paso 0, imagen 3 de 3
  • Tight plastic clips secure the left and right edges of the rear case.
  • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
  • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
Insertar traducción aquí
-[title] Release the rear case clips
-[* icon_note] Tight plastic clips secure the left and right edges of the rear case.
+[* icon_note] Tight plastic clips secure the [link|https://guide-images.cdn.ifixit.com/igi/cSFE5AIPQAOqYn5A.full|left|new_window=true] and [link|https://guide-images.cdn.ifixit.com/igi/gssrnZ6hIcnAIKxY.full|right|new_window=true] edges of the rear case.
[* black] Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
-[* black] Slide the spudger along the left edge and gently pry the shells apart to separate the clips.
+[* black] Slide the spudger along the left edge and gently pry the shells apart to release the clips.
