Saltar al contenido principal
Polar Wind 8" High Velocity Fan Blades Replacement
Inglés
Español
Paso 5
Polar Wind 8" High Velocity Fan Blades Replacement: paso 0, imagen 1 de 3 Polar Wind 8" High Velocity Fan Blades Replacement: paso 0, imagen 2 de 3 Polar Wind 8" High Velocity Fan Blades Replacement: paso 0, imagen 3 de 3
  • Firmly grasp the base of the blades, pushing it down and turning clockwise to slide down to the base of the rod.
  • Use a pair of pliers to remove the center disk by pinching the rim and pulling upwards.
  • Once it is loosened, squeeze the bottom of the disk and the tip of the rod between your pliers to more easily remove the disk.
  • The disk may be difficult to remove. Using lube may help slide it off more easily, but it is not required.
Insertar traducción aquí
