Saltar al contenido principal
Reemplazo de tarjeta de Antena WiFi de Xbox Series X
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Xbox Series X Wi-Fi Antenna Board Replacement: paso 0, imagen 1 de 3 Xbox Series X Wi-Fi Antenna Board Replacement: paso 0, imagen 2 de 3 Xbox Series X Wi-Fi Antenna Board Replacement: paso 0, imagen 3 de 3
  • Grip the antenna board and pull it directly away from the center chassis to disconnect it.
  • Don't pull the antenna board up until it's completely disconnected.
  • Remove the antenna board.
  • During reassembly, align the board's connector with the port on the center chassis and press to reconnect.
Agarra la antena de la tarjeta y jálalo directamente del chasis central para desconectarlo.
No jales la antena de la tarjeta hacia arriba hasta que este completamente desconectada.
Remueve la antena de la tarjeta.
Durante el reensamble, alinea los conectores de la tarjeta con el puerto en el chasis central y presiona para reconectar.
[* black] Grip the antenna board and pull it directly away from the center chassis to disconnect it.
- [* icon_caution] Don't pull the antenna board ***up*** until it is completely disconnected.
+ [* icon_caution] Don't pull the antenna board ***up*** until it's completely disconnected.
[* black] Remove the antenna board.
[* icon_reminder] During reassembly, align the board's connector with the port on the center chassis and press to reconnect.
