Saltar al contenido principal
Reemplazo de la placa LED de la PlayStation 5
Inglés
Español
Traduciendo paso 1
Paso 1
PlayStation 5 LED Board Replacement, Disconnect the LED ribbon cable: paso 0, imagen 1 de 2 PlayStation 5 LED Board Replacement, Disconnect the LED ribbon cable: paso 0, imagen 2 de 2
  • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the LED board ribbon cable.
Usa un par de pinzas para sacar la lengüeta azul directamente del conector para desconectar el cable plano de la placa LED.
[title] Disconnect the LED ribbon cable
-[* black] Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the LED board ribbon cable.
+[* black] Use a pair of [product|IF145-020|tweezers] to pull the blue pull tab directly away from the connector to disconnect the LED board ribbon cable.
