Traduciendo paso 1
Paso 1
Remove the x-clamp
Insert a 1.5 mm flathead screwdriver from the top between the heat sink pin and the x-clamp.
Pry the x-clamp out and away from the heat sink pin to loosen the x-clamp.
[title] Remove the x-clamp | |
- | [* black] Insert a 1.5 mm flathead screwdriver from the top between the heat sink pin and the x-clamp. |
+ | [* black] Insert a [product|IF145-431|1.5 mm flathead] screwdriver from the top between the heat sink pin and the x-clamp. |
[* black] Pry the x-clamp out and away from the heat sink pin to loosen the x-clamp. | |
[* icon_caution] Do not attempt to completely release the x-clamp with this technique. |
