Saltar al contenido principal
Desmontaje de AirPods Max
Inglés
Español
Paso 18
AirPods Max Teardown: paso 0, imagen 1 de 2 AirPods Max Teardown: paso 0, imagen 2 de 2
  • Not merely T4, not only T3, not just T2, but even a few teeny-tiny T1 Torx screws later, the joint comes apart and shows its springs, miniscule bearings, and precision-machined micro-housings.
  • The two large springs provide that gentle clamping pressure on your skull, while the two smaller springs perform a neat trick that we'll reveal in a minute.
  • Why did Apple go to such lengths to over-engineer these parts? Here are a few factors:
  • The two points in any headphone where the headband meets the ear cup are paramount for comfort. The joint needs to move with multiple degrees of freedom to sit comfortably on the wearer's head, and be sturdy enough to be yanked around a bit during the putting-on and resizing process.
  • Additionally, headphones are little pockets of pure vibration. Inside both ear cups, the drivers vibrate rapidly for extended periods of time to create sound for your ear holes. So any joint hardware inside the ear cup needs to be pretty robust.
  • It was rumored that Apple wanted to design the AirPods Max headband to be easily-swappable like its magnetic ear cups. That feature was thought to be missing from the final design, but this joint is so complex it just might have one more thing up its sleeve...
No sólo T4, no sólo T3, no sólo T2, sino incluso unos pocos diminutos tornillos Torx T1 más tarde, la junta se desmonta y muestra sus muelles, minúsculos cojinetes y microcarcasas mecanizadas con precisión.
Los dos grandes muelles proporcionan esa suave presión de sujeción en el cráneo, mientras que los dos muelles más pequeños realizan un truco limpio que revelaremos en un minuto.
¿Por qué Apple llegó a tales extremos para sobre-ingeniar estas partes? Aquí hay algunos factores:
Los dos puntos de cualquier auricular donde la banda de la cabeza se encuentra con el auricular son primordiales para la comodidad. La articulación necesita moverse con múltiples grados de libertad para sentarse cómodamente en la cabeza, y ser lo suficientemente resistente para ser tirada un poco durante la colocación y el cambio de tamaño.
Además, los auriculares son pequeños bolsillos de pura vibración. Dentro de ambos auriculares, los drivers vibran rápidamente durante largos períodos de tiempo para crear sonido para sus orificios auditivos. Por lo tanto, cualquier unión dentro de los auriculares debe ser bastante robusta.
Se rumoreaba que Apple quería diseñar la diadema de AirPods Max para que fuera fácilmente intercambiable como sus auriculares magnéticos. Se pensó que esa característica faltaba en el diseño final, pero esta articulación es tan compleja que podría tener una cosa más debajo la manga...
