Traduciendo paso 6
Paso 6
Replacement of main board
Remove all connectors if you want to replace the mainboard. All connectors work similarly - you need to turn up the black / back part of the connector and pull out the cables. The two exceptions are the battery connector which simply needs to be pulled or pried upwards. Same for the WiFi coax connector.
There are 6 screws with special washers that are holding the main board to the frame.
