Saltar al contenido principal
Canon PowerShot SD 600 Exterior Frame Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 9 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Canon PowerShot SD 600 Exterior Frame Replacement: paso 0, imagen 1 de 3 Canon PowerShot SD 600 Exterior Frame Replacement: paso 0, imagen 2 de 3 Canon PowerShot SD 600 Exterior Frame Replacement: paso 0, imagen 3 de 3
  • Carefully pull apart the two parts of the exterior frame.
  • Use the spudger to pry apart the two frame components.
  • Once disconnected, the two parts of the frame can be easily separated by using your fingers.
  • The rear frame should be removed first.
  • There should be an O-ring on the front face of the camera. Ensure to keep the O-ring with the front part of the frame.
  • The orientation for the pictures is changed in order to properly show which piece is being removed.
Insertar traducción aquí
