Saltar al contenido principal
Canon PowerShot SD 600 Rear Control Board Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Paso 2
Canon PowerShot SD 600 Rear Control Board Replacement: paso 0, imagen 1 de 3 Canon PowerShot SD 600 Rear Control Board Replacement: paso 0, imagen 2 de 3 Canon PowerShot SD 600 Rear Control Board Replacement: paso 0, imagen 3 de 3
  • Using the spudger, gently push up the board from the pins underneath it.
  • Follow the board up and around the camera, gently unseating the board and cables.
  • The speaker will still be connected to the board via two small power wires. Use the tweezers to pull and unplug the power connector from the main rear accessory board.
  • For best results, grip the tweezers as close to the plug as possible.
Insertar traducción aquí
