Saltar al contenido principal
Samsung Galaxy Note9 Vervanging van de batterij
Inglés
Holandés
Traduciendo paso 1
Paso 1
Samsung Galaxy Note9 Battery Replacement, Remove the battery: paso 0, imagen 1 de 3 Samsung Galaxy Note9 Battery Replacement, Remove the battery: paso 0, imagen 2 de 3 Samsung Galaxy Note9 Battery Replacement, Remove the battery: paso 0, imagen 3 de 3
Remove the battery
  • Apply 1-2 drops of high-concentration (90% or greater) isopropyl alcohol in the battery well along the bottom and in the upper-left corner of the battery.
  • Using too much alcohol can damage the display.
  • Wait a couple of minutes for the alcohol to soften the adhesive under the battery.
  • Tilt the phone at various angles to help the alcohol flow under the battery.
Dien een aantal druppels isopropyl alcohol (>90%) toe in de openingen aan de onderkant en in de linker bovenhoek van de batterij.
Wacht een aantal minuten om de alcohol in te laten trekken en zo de lijm onder de batterij te verzachten.
Kantel de telefoon in verschillende hoeken om ervoor te zorgen dat de alcohol onder de batterij stroomt.
[title] Remove the battery
-[* black] Apply a few drops of 90% isopropyl alcohol in the battery well along the bottom and in the upper-left corner of the battery.
+[* black] Apply 1-2 drops of high-concentration (90% or greater) isopropyl alcohol in the battery well along the bottom and in the upper-left corner of the battery.
+ [* icon_caution] Using too much alcohol can damage the display.
[* black] Wait a couple of minutes for the alcohol to soften the adhesive under the battery.
[* black] Tilt the phone at various angles to help the alcohol flow under the battery.
