Saltar al contenido principal
Nest Hello Casing and Faceplate Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 1
Paso 1
Nest Hello Casing and Faceplate Replacement: paso 0, imagen 1 de 1
  • Insert the pick between the black faceplate and white casing of the Nest Hello.
  • Pry the faceplate away from the device with the opening pick.
  • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
  • Completely remove the faceplate from the device, do not be afraid to pull hard.
Insertar traducción aquí
