Saltar al contenido principal
Infinity v2 10.1 Battery Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 1
Paso 1
Infinity v2 10.1 Battery Replacement: paso 0, imagen 1 de 3 Infinity v2 10.1 Battery Replacement: paso 0, imagen 2 de 3 Infinity v2 10.1 Battery Replacement: paso 0, imagen 3 de 3
  • Pry beneath each side of the battery using a spudger.
  • The adhesive may be too strong to manually remove, so heat can be applied using the iOpener. This evenly heats the adhesive and allows the battery to be lifted away easier. Do not place the iOpener directly on the battery; always apply heat on the opposite side of the device.
  • You may use a blow-dryer on a cool setting. Keep the dryer moving and at least 6 inches from the battery to prevent dangerous bubbling of the battery due to excess heat.
Insertar traducción aquí
