Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver. Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
  • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
Con el destornillador de tres alas, desatornille los tornillos que sujetan la cubierta posterior al dispositivo. Los seis tornillos que deben quitarse incluyen:
Cuatro tornillos de tres alas n.o 00 de 6,45 mm que se encuentran en las esquinas del dispositivo.
Dos tornillos de tres alas n.o 00 de 4,6 mm que se encuentran en la parte superior central y en la parte inferior central del dispositivo.
-[* orange] Using the tri-wing screwdriver, unscrew the screws holding the back cover to the device. The six screws that need to be removed include:
- [* orange] Four #00 6.45mm tri-wing screws that are located at the corners of the device.
- [* yellow] Two #00 4.6mm tri-wing screws that are located at the top-center and bottom-center of the device.
+[* yellow] Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
+[* green] Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
