Saltar al contenido principal
Dell XPS 15 9575 Screen Replacement
Inglés
Español
Paso 2
Dell XPS 15 9575 Screen  Replacement: paso 0, imagen 1 de 3 Dell XPS 15 9575 Screen  Replacement: paso 0, imagen 2 de 3 Dell XPS 15 9575 Screen  Replacement: paso 0, imagen 3 de 3
  • Two silver screws are holding down the aluminium dust cover protecting the display connections.
  • Use the Phillips #0 screwdriver to remove two 3.2 mm silver screws.
  • Use the tweezers to remove the grey cover.
  • Under the cover, you will see one white wire and one black wire.
  • Use the tweezers and gently pull straight up on each of the coaxial cables to disconnect them from their specialized brackets.
  • Reposition the tweezers farther up on the wire and pull forward to remove the wires from the plastic guides that hold the them in place.
Insertar traducción aquí
