Saltar al contenido principal
Hoe gebruik je op maat gemaakte kleefstrips?
Inglés
Holandés
Paso 8
How to Apply Custom-cut Adhesive Strips, Further strengthen the adhesive bond: paso 0, imagen 1 de 3 How to Apply Custom-cut Adhesive Strips, Further strengthen the adhesive bond: paso 0, imagen 2 de 3 How to Apply Custom-cut Adhesive Strips, Further strengthen the adhesive bond: paso 0, imagen 3 de 3
  • Once you've installed your part or sealed up your device, you can strengthen the bond by heating up the adhesive.
  • Soft adhesives, which are usually messy and hard to clean, benefit from a reheat.
  • Harder adhesives that resemble tape may not benefit as much, but the heat can help the adhesive fill in gaps.
  • Use a hair dryer, iOpener, or heat gun to lightly heat the part or closed device in the areas where the new adhesive was applied.
Insertar traducción aquí
+[title] Further strengthen the adhesive bond
+[* icon_note] Once you've installed your part or sealed up your device, you can strengthen the bond by heating up the adhesive.
+ [* icon_note] Soft adhesives, which are usually messy and hard to clean, benefit from a reheat.
+ [* icon_note] Harder adhesives that resemble tape may not benefit as much, but the heat can help the adhesive fill in gaps.
+[* black] Use a [guide|157348|hair dryer|new_window=true], [guide|25705|iOpener|new_window=true], or [guide|151116|heat gun|new_window=true] to lightly heat the part or closed device in the areas where the new adhesive was applied.
