Saltar al contenido principal
Cómo aplicar tiras adhesivas cortadas a medida
Inglés
Español
Paso 3
How to Apply Custom-cut Adhesive Strips, Orient the adhesives: paso 0, imagen 1 de 3 How to Apply Custom-cut Adhesive Strips, Orient the adhesives: paso 0, imagen 2 de 3 How to Apply Custom-cut Adhesive Strips, Orient the adhesives: paso 0, imagen 3 de 3
  • Custom-cut adhesive strips are shaped such that they install onto a device in only one way. When orienting your adhesive, look for distinct cutouts or markings that hint at how to place the adhesive:
  • Cutouts for components or liner pull-tabs in the frame
  • Alignment markings outlining the desired position
  • Holes for spring contacts or cameras
  • Most adhesive strips will have a neutral/clear liner covering one side and a colored liner covering the other. You'll be peeling the neutral/clear liner first and applying the exposed adhesive to its corresponding surface.
  • For example, if your back cover adhesive's clear liner faces the phone frame, you'll stick the adhesive strip to the frame first. If the clear liner faces the back cover, you'll stick the strip to the cover first.
  • If the adhesive comes in pieces, match each piece to the device by its contours and set them next to your device.
  • To ease the process of removing liners without losing alignment, you can align the strip to its intended position on the device, then tape one edge down to hold the strip in place.
Las tiras adhesivas cortadas a medida tienen una forma tal que se instalan en un dispositivo de una sola manera. Al orientar el adhesivo, busca cortes o marcas distintas que indiquen cómo colocar el adhesivo:
Recortes para componentes o lengüetas de revestimiento en el marco
Marcas de alineación que describen la posición deseada.
Orificios para contactos de resorte o cámaras.
La mayoría de las tiras adhesivas tendrán un revestimiento neutro/transparente que cubrirá un lado y un revestimiento de color que cubrirá el otro. Primero pelarás el revestimiento neutro/transparente y aplicarás el adhesivo expuesto en su superficie correspondiente.
Por ejemplo, si el revestimiento transparente del adhesivo de la cubierta posterior mira hacia el marco del teléfono, primero pegarás la tira adhesiva al marco. Si el revestimiento transparente mira hacia la cubierta posterior, primero pegarás la tira a la cubierta.
Si el adhesivo viene en pedazos, haz coincidir cada pieza con el dispositivo por sus contornos y colócalas al lado de tu dispositivo.
Para facilitar el proceso de quitar los revestimientos sin perder la alineación, puedes alinear la tira en su posición prevista en el dispositivo, luego pegar con cinta adhesiva un borde para mantener la tira en su lugar.
