Saltar al contenido principal
Dell XPS 15 9575 Battery Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Holandés
Paso 2
Dell XPS 15 9575 Battery Replacement: paso 0, imagen 1 de 2 Dell XPS 15 9575 Battery Replacement: paso 0, imagen 2 de 2
  • Use a plastic opening pick to pry the black battery cable away from its silver adapter.
  • Hold the pick at 35 degrees from the computer and push towards the battery to remove the cable from its socket.
  • Do not push straight into the battery cable as this could damage the adapter.
  • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
Insertar traducción aquí
