Saltar al contenido principal
SiliconGraphics Onyx Teardown
Inglés
Holandés
Paso 22
SiliconGraphics Onyx Teardown: paso 0, imagen 1 de 3 SiliconGraphics Onyx Teardown: paso 0, imagen 2 de 3 SiliconGraphics Onyx Teardown: paso 0, imagen 3 de 3
  • The SCSI devices are mounted on sleds. The sled can hold 3.5 inch and 5.25 inch devices.
  • Full-height devices can be accommodated but the bay above the bay in use will be inaccessible.
  • To remove a sled, slide the green lever to the left.
  • This sled holds the system disk, a 10k RPM 9GB Quantum. Slow and small by today's standard, it is typical for late 90s technology.
  • The sled's power connection.
  • Bus 0 connection (single-ended)
  • Bus 1 connection (differential signaling)
  • The Device ID can be set through a switch on the front panel. This switch plugs into the disk.
Insertar traducción aquí
