Saltar al contenido principal
SiliconGraphics Onyx Teardown
Inglés
Español
Paso 8
SiliconGraphics Onyx Teardown: paso 0, imagen 1 de 1
  • The IP25 board contains 4 MIPS R10000 processors, running at 195Mhz with 2MB of cache on-die.
  • The CPU chip is mounted to an HIMM PCB. The connections are made with a Cinch CIN::APSE, which appears similar to an LGA socket, except nothing holds the "pins" (bits of steel wool) in place when they are not connected. DO NOT REMOVE the HIMMs unless required, and INSPECT the connector with a microscope during reassembly! The pins are easy to lose or short out!
  • Mips R10000 processor
  • Everest data bus ASICs
  • Everest address bus ASIC
  • 5V power converter
  • 3.3V power converters
  • glue logic and microcode eproms
Insertar traducción aquí
