Saltar al contenido principal
Dell Inspiron LCD Screen Replacement
Inglés
Holandés
Paso 6
Dell Inspiron LCD Screen Replacement: paso 0, imagen 1 de 2 Dell Inspiron LCD Screen Replacement: paso 0, imagen 2 de 2
  • Start by gently prying off the camera cable from the back screen. It should come off fairly easily but a spatula can also be used to pry under the cable and help remove it.
  • Next you must remove the video cable plugged into the back on the screen. It is a bigger version of the camera cable. However this connector is covered with clear tape to prevent the cable from unplugging by accident. Gently pull up an edge of the tape then slowly peel down away from the screen.
  • Next gently pry the rest of the video and camera cables from the back and your broken screen should be free to remove.
Insertar traducción aquí
