Saltar al contenido principal
Canon PowerShot SX60 HS Back Panel Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 7 guías que incluyen este paso.
Inglés
Español
Paso 3
Canon PowerShot SX60 HS Back Panel Replacement: paso 0, imagen 1 de 2 Canon PowerShot SX60 HS Back Panel Replacement: paso 0, imagen 2 de 2
  • Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
  • Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
  • Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
  • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
Insertar traducción aquí
