Saltar al contenido principal
Canon PowerShot SX60 HS Front Panel Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Paso 2
Canon PowerShot SX60 HS Front Panel Replacement: paso 0, imagen 1 de 3 Canon PowerShot SX60 HS Front Panel Replacement: paso 0, imagen 2 de 3 Canon PowerShot SX60 HS Front Panel Replacement: paso 0, imagen 3 de 3
  • Remove the 5mm Phillips #00 screw located on the left side below the microphone connection.
  • Remove the 4mm Phillips #00 screw located on the bottom left of the camera.
  • Remove the 5mm Phillips #00 screw located on the bottom center of the camera.
  • Pop open the flash and remove the 5mm Phillips #00 screw located under the flash.
Insertar traducción aquí
