Saltar al contenido principal
Dell Latitude 3450 RAM Replacement
Inglés
Holandés
Paso 2
Dell Latitude 3450 RAM Replacement, Removing the Rear Cover: paso 0, imagen 1 de 3 Dell Latitude 3450 RAM Replacement, Removing the Rear Cover: paso 0, imagen 2 de 3 Dell Latitude 3450 RAM Replacement, Removing the Rear Cover: paso 0, imagen 3 de 3
  • Loosen the two Phillips head screws.
  • These screws should back out, but should not actually be removable.
  • Locate the indent on the rear cover half way between the two Phillips head screws.
  • Insert your spudger to help pry up the rear cover.
  • It may be necessary to run the spudger along the side with the indent to help release the clips
  • Lift off the rear cover.
Insertar traducción aquí
