Saltar al contenido principal
iPad Mini 3 Wi-Fi LCD Shield Plate Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 16 guías que incluyen este paso.
Inglés
Holandés
Paso 20
iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: paso 0, imagen 1 de 3 iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: paso 0, imagen 2 de 3 iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: paso 0, imagen 3 de 3
  • Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
  • Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
  • There are quite a few things to avoid beneath the lower bezel, so study the third image closely:
  • Antennas
  • Home button cavity
  • Digitizer cable
  • The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
Insertar traducción aquí
