Saltar al contenido principal
iPad Mini 3 Wi-Fi LCD Shield Plate Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 16 guías que incluyen este paso.
Inglés
Holandés
Paso 3
iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: paso 0, imagen 1 de 3 iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: paso 0, imagen 2 de 3 iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: paso 0, imagen 3 de 3
  • Carefully place a suction cup halfway up the heated side.
  • Be sure the cup is completely flat on the screen to get a tight seal.
  • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
  • Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
Insertar traducción aquí
