Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
In the following steps you'll be cutting through the adhesive that adheres the screen to the phone. For reference, the back side of the screen is shown at left. Note the narrow clearance between the edge of the screen and the LCD underneath the glass. If you plan to re-use your screen, be extra careful as you cut through the adhesive in the following steps.
  • In the following steps you'll be cutting through the adhesive that adheres the screen to the phone.
  • For reference, the back side of the screen is shown at left. Note the narrow clearance between the edge of the screen and the LCD underneath the glass.
  • If you plan to re-use your screen, be extra careful as you cut through the adhesive in the following steps.
En los siguientes pasos, cortarás el adhesivo que adhiere la pantalla al teléfono.
Como referencia, la parte posterior de la pantalla se muestra a la izquierda. Observ el estrecho espacio entre el borde de la pantalla y la pantalla LCD debajo del vidrio.
Si planeas reutilizar tu pantalla, ten mucho cuidado al cortar el adhesivo en los siguientes pasos.
