Saltar al contenido principal
Panasonic Lumix DMC-G7 LCD Panel Replacement
Inglés
Holandés
Paso 6
Panasonic Lumix DMC-G7 LCD Panel Replacement: paso 0, imagen 1 de 3 Panasonic Lumix DMC-G7 LCD Panel Replacement: paso 0, imagen 2 de 3 Panasonic Lumix DMC-G7 LCD Panel Replacement: paso 0, imagen 3 de 3
  • Remove the two indicated ribbon cables before separating the two halves of the camera.
  • Using a flat object, pry open the black tabs above the ribbon cable connectors by gently pulling away from the motherboard.
  • An opening pick is recommended, but any equally small and flat object will work.
  • Ribbon cables are fragile, so put as little stress on them as possible.
Insertar traducción aquí
