Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 42 guías que incluyan este paso.
Inglés
Español
Paso 10
In the next few steps, you'll be sliding a spudger between the LCD and the metal backing plate to fully separate the LCD from the adhesive beneath. Insert the flat end of a spudger between the LCD frame and the metal backing plate. Be sure to get the spudger between the LCD frame and backing plate, and not beneath the plate. Prying up on the plate will damage it, because it is screwed down to the rear case beneath the LCD.
  • In the next few steps, you'll be sliding a spudger between the LCD and the metal backing plate to fully separate the LCD from the adhesive beneath.
  • Insert the flat end of a spudger between the LCD frame and the metal backing plate.
  • Be sure to get the spudger between the LCD frame and backing plate, and not beneath the plate. Prying up on the plate will damage it, because it is screwed down to the rear case beneath the LCD.
Insertar traducción aquí
