Saltar al contenido principal
Dell Precision 5530 Disassembly
Inglés
Holandés
Paso 9
Dell Precision 5530 Disassembly, Remove the motherboard: paso 0, imagen 1 de 2 Dell Precision 5530 Disassembly, Remove the motherboard: paso 0, imagen 2 de 2
  • Note: in the first image, the WiFi card is still in place, but it needs to be removed before the motherboard can be removed. See step 8 for that process.
  • There are five cables that must be removed. Two are standard plugs (highlighted in orange: the charging cable (top), and the speakers (bottom)) and three are locking ribbon cables (highlighted in pink (from left: power button, trackpad, keyboard)).
  • Be very careful with the locking ribbon cables! It's easy to pull them off the motherboard entirely! If you're not comfortable removing these, look up a video or other instruction set for how to handle these.
  • There are then four Phillips screws (red circles) that need to be removed.
  • Finally, the motherboard can be removed. USE CAUTION! Pull it up away from the machine slightly, and then slide it away from the hinge. It should come out easily.
Insertar traducción aquí
