Saltar al contenido principal
Dell Precision 5530 Disassembly
Inglés
Español
Paso 2
Dell Precision 5530 Disassembly, Bottom case: paso 0, imagen 1 de 3 Dell Precision 5530 Disassembly, Bottom case: paso 0, imagen 2 de 3 Dell Precision 5530 Disassembly, Bottom case: paso 0, imagen 3 de 3
Bottom case
  • Turn off the machine, close the lid, and flip it over so it's laying upside down, hinge away from you.
  • Recommend a soft anti-static surface for this so as to not scratch the exterior.
  • Remove the ten (10) torx (T5) screws around the edges of the case.
  • Flip up the magnetic "lid" that says "Precision 5530" to expose the service tag and two Phillips (PH1) screws. Remove these.
  • Starting from the hinge side, slowly lift the rear case off. There are a few snaps, this is normal. There are no cables attached, so when it comes free, put it off to the side.
Insertar traducción aquí
