Traduciendo paso 8
Paso 8
Rotate the device so the battery port is facing you.
Remove six 5.5 mm Phillips #0 screws on both sides of the device directly behind the screen.
Rotate the device so the battery port is facing away from you.
Grab the screen with your fingers and gently pull it free. Carefully set it aside making sure that you don't accidentally unplug it from the device.
