Saltar al contenido principal
iPhone 6s Plus Speaker Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Holandés
Paso 6
iPhone 6s Plus Speaker Replacement: paso 0, imagen 1 de 3 iPhone 6s Plus Speaker Replacement: paso 0, imagen 2 de 3 iPhone 6s Plus Speaker Replacement: paso 0, imagen 3 de 3
  • Carefully lift the antenna cable and de-route it from the edge of the phone. Use the point of a spudger to help lift the cable free it from the retaining clips.
  • If the cable does not have enough room to lift up, loosen this Phillips screw securing the logic board so that the board can give more wiggle room.
  • Be sure to re-tighten this screw during re-installation.
  • If the cable snags near the SIM reader, it's likely caught on the SIM tray ejection mechanism. Use the point of a spudger to slide the plastic rod out of the way.
  • During re-installation, be sure to route the antenna cable underneath the logic board corner.
  • During reassembly, you can also re-insert the SIM card tray after re-routing the antenna cable.
  • If you feel any resistance, stop and make sure that the tray isn't snagging the antenna cable.
Insertar traducción aquí
